-   -   Power Steering Fittings/Hose Question (https://www.offshoreonly.com/forums/general-q/334794-power-steering-fittings-hose-question.html)
corey331 02-22-2016 12:16 PM
OK, so I am down to the final steps of rigging on my LSX swap into my Checkmate. Unfortunately, when I sold the complete 454 out of the boat. I left the power steering lines on the pump with the motor. Being that stock line lengths won't work and I'm 99% sure that the fittings on my power steering pump are different than a Merc's, I'm going to have to have some hoses made. My main question is, what are the threads on the fittings that go into the steering rack? My boat is a 98 and the Bravo One is the stock one that came on the boat if that makes any difference. Any help is greatly appreciated!!!
GLENAMY 242SS 02-22-2016 02:12 PM
Which steering actuator do you have, Saganaw (external metal hoses) or Brazilian? If it is the Saganaw, forget about hoses being made (I do have a set for this one I will give you). The Brazilian uses a metric thread with an "O" ring on the fitting, again I had no luck finding this fitting also.
corey331 02-22-2016 04:12 PM
This will help, here is a pic of my steering ram. To me it looks like the Brazilian and I'm pretty sure it uses o-rings.
http://s25.postimg.org/q97gcb4fz/image.jpg
GLENAMY 242SS 02-22-2016 05:48 PM
Yes, Brazilian, newer style hoses. Metric with O rings, again I went to several commercial hose vendor/fabricators and was unable to get any made.
corey331 02-22-2016 07:08 PM
Thanks for the reply. I'm wondering if something like this won't work to adapt it over to standard threads? It might be worth the $16 to see.
http://www.summitracing.com/parts/clp-605sol
GLENAMY 242SS 02-22-2016 08:11 PM
If they work that would be great. Good Luck
hallj 02-22-2016 08:18 PM
You're on the right track, can you get a metric screw in there to verify the thread?
These Earl's adapters will get you to a JIC/AN that your hose vendor can adapt to with ease.
https://www.holley.com/products/plum...tion_adapters/
Jeff
BUP 02-23-2016 01:17 AM
would 5 thru 8 help from the Merc parts list ?
http://www.mercruiserparts.com/Show_...ering+Actuator
corey331 02-23-2016 05:42 AM
Thanks for the replies guys, they are greatly appreciated!! Push come to shove, I'll just order the new connections. Thanks again!!
ezstriper 02-23-2016 12:07 PM
just get a set for what you had, the pump fitting should be the same, saginaw pump, the return is just a 3/8 slip on, make sure you use a P/S cooler
corey331 02-23-2016 01:56 PM
I'm not using the stock LS pump and with the location of my PS pump, the hoses will be longer than stock. As far as a cooler goes I have a 24" x 3" diameter oil cooler w/thermostat and a PS cooler. So I should be good as long as I get the right fittings. Which I should be able to do.
ezstriper 02-24-2016 06:34 AM
what pump are you running ? still location should be close enough for a factory line to reach, the return you can buy bulk p/s hose for that(don't use fuel line) to make whatever run you need, you can contact AGR they build the pumps for a lot of custom deals and probably have the fittings
corey331 02-24-2016 08:01 AM
Cool, I 'll check out AGR. Thanks!!
