their ya go,good piston&cam combo.should make good power for a long time.
This is where I'm at now.
Gen VI 454 .030 over with http://www.cnc-motorsports.com/diamo...-280-bore.html And 088 heads worked over And this cam http://m.summitracing.com/parts/cca-01-445-8 Standard rods and crank Performer rpm holley 800 DP. Stainless marine exhaust. I was rolling 69 mph at 5000 rpm before with 24P Bravo 1 |
Will this cam be an improvement to the stock unit?
Originally Posted by distantthunder
(Post 4414144)
Originally Posted by SB
(Post 4414146)
Does Dolly Parton have big boobs ?
HAHAHA, Great answer. Going on order tonight. |
(Post 4414144)
You switched cams without me seeing. So I take back my Dolly Parton boobs. Why are we switching ? |
(Post 4414148)
Wait, wait, wait.
You switched cams without me seeing. So I take back my Dolly Parton boobs. Why are we switching ? I got a clean Gen VI standard block from my buddy because I was uncomfortable over boring my existing block another .030 over. So I am reusing the .030 over pistons and boring the replacement .030 over. The previous cam that I listed had a higher RPM range. I wanted to bring it down a notch as I was only able to spin around 5000 RPM last year. The year before last I was WOT @ 5300 but my slip was too high so I had bblades work the prop over to drop 300 RPM and gain 6 MPH. |
Rectangle port heads on a 454 really need to be spun up a little higher to make the most of the combination. Although I didn't see it mentioned here I am assuming this motor is going into the 22 foot Formula in your signature? If so, you don't need a lot of torque with a 454 in a 22 foot boat. Cam it a bit more and let it rev a little higher.
Originally Posted by donzi matt
(Post 4414163)
I wouldn't hesitate to spin a forged bottom end 454 to 5600 RPM. What was the engine like that spun to 5000 RPM last year? If you are going to make more power with this setup you may just be able to carry the prop currently on the boat to your target RPM.
| All times are GMT -5. The time now is 03:12 AM. |
