Originally Posted by BUP
(Post 4417070)
Autos fair alot better with fuel than boats. Boats fuel see long sit times and condensation, water and corrosion in the fuel system that 98 % of autos will never see.
Many fuel injector table top machines come from China and are junk. There is some quality machines on the market. The ASNU table top machine is 10 K. The Australians started this many years ago with table top testing machines called New Age. Some have custom made machines and those do alot better at testing injectors along with cleaning them. RC Engineering is one of them who made an over the top machine(s). Injectors are electrical and mechanical devices. A good machine can run all the tests and test for internal shorts among other things. You can check Spray patterns , leaks, flow volume, change fuel pressures, change rpms some up to 15K, check flow volumes and balance, clean and back flush injectors for the jist of it. The back flush is a feature to have but better to have it separate from the machine. Cheap machines do not have internal filters to filter out its flow testing fluid after it runs thru the injector. Some services incorp a lab scope into their machine as well |
Originally Posted by oconnor marine
(Post 4416961)
I have twin 1988 5.7l 320hp mercruiser racing EFI engines/bravos in my 272 sr1 Formula.
I purchased it a few weeks ago, ran on the hose and they ran rough and eye-burning rich. I removed the fuel water separator filters filled new ones with Techron concentrated fuel injector cleaner( black bottle) ran the motors and now they run smooth start instantly and no rich smell. Just thought I would pass this along. I have Never heard of this and I think it works |
Originally Posted by articfriends
(Post 4416981)
Most the time ultrasonic cleaning then flowed on bench is a world better than any additive, mainly the ultrasonic part. Thats why i made the investment and bought my own machine, Smitty
You too!? Nice! https://www.jewishsoftware.com/produ...Sonic-Wave.jpg |
1 Attachment(s)
Originally Posted by ICDEDPPL
(Post 4417250)
That is funny about the jewelry machine. You can not clean injectors with the jewelry machine unless you pulse the injector among a few other things, you would need to do a of that for at least bare min.15 minutes straight. The only thing that jewelry machine will do is clean it externally plus you never drop the whole injector in any cleaning solution or ultrasonic bath.
icdedppl has carburetors. But good info about injectors in case anyone is thinking it could be used that way.
^^^ I own cars you know.
| All times are GMT -5. The time now is 10:13 PM. |
