RPM to prop for vs dyno chart.
I just pulled my motor off the dyno. It made 572hp @5600 when cool. After multiple pulls it made 551@5600
I am using the hot pulls to go off of. 3500-383hp 3600-395 3700-405 3800-417 3900-425 4000-427 4100-436 4200-444 4300-450 4400-458 4500-467 4600-478 4700-484 4800-490 4900-503 5000-512 5100-525 5200-538 5300-544 5400-546 5500-550 5600-551 Last year with a tired 420hp, I could spin a 23 mirage to 5000rpm. This year I was thinking either a 25 or 27 mirage plus and propping it for 5300rpm. What do you guys think my target WOT rpm should be? And what prop would get me there? |
I'm curious what all did you do to your engine to go from 420 to 572 hp?
Slightly better heads, bigger cam and a supercharger.
Originally Posted by 79formula
(Post 4418384)
5700-5800RPM light load, opinions might vary. |
I would prop to your peak HP which appears to be around 5600. Otherwise you are leaving performance on the table.
As a baseline I would start in water testing with your existing prop. Yes you may be under propped but you also haven't spun that prop past 5000 rpm either. Once you get a feel for how your boat and prop perform when north of 5000 rpm you can start with prop selection. If you need more prop then work up the pitch ladder. |
trial and error. You'll prolly end up with the 25 if I had to guess but like rookie said you may end up with same prop and spin it a little more. Gotta tune it for what it likes including boat characteristics, handling etc. I can give u an example from back in the day with a twin engine 28 I had. Started out with a pair a toad 330's and then built some others with your basic 454 upgrades including worked dart heads, intakes, carbs, comp etc. ended up with 480 hp. So close to yours in regards to gains in power. 150 + -.
Boat ran came new with 23 mirage that ran 46-4700 with the 330's and ended up going with 25's that ran a conservative 5,600 with the new builds. Will give you some kind of an idea. What were your torque numbers. Also curious what cam you swapped out to cause if I'm not mistaking the 420hp cam is the same one merc used in their 525 sc's. You running 250's or tuned 177's. |
Personally I've never had any luck running bbc's much under 5,400/5,500. Anything much less than that just feels lazy.
577 torque at 3600rpm. I went from the 132561 "420" cam to a crane 134561. It made over 550lbs almost everywhere. Torque monster.
I am running a 177 525sc setup. I am running that 134561 cam and 9:1 compression. So I am a little hotter that the standard issue 525sc.
I think I'd try the 25 Mirage plus...
| All times are GMT -5. The time now is 06:51 PM. |
