F.A.S.T. "Classic" grey box settings...
I'm using an older FAST ECM for my 555 build and am having trouble finding information on it...
When I pull up the ECU configuration menu, "TBI FI Mode Enable" is selected... I understand it would've had to be sent to FAST to have the mode changed, but they no longer support it, so I'm SOL.... Any idea what the difference IS in this mode as opposed to "Bank - to - Bank" mode ? THANKS ! Doug http://i130.photobucket.com/albums/p...ps0ttbaoot.jpg |
Originally Posted by Boatally Insane
(Post 4420307)
When I pull up the ECU configuration menu, "TBI FI Mode Enable" is selected... I understand it would've had to be sent to FAST to have the mode changed, but they no longer support it, so I'm SOL.... Any idea what the difference IS in this mode as opposed to "Bank - to - Bank" mode ? THANKS ! Doug http://i130.photobucket.com/albums/p...ps0ttbaoot.jpg If you are on yellow bullet go to the electronic section and post there lots of people there can help. |
Just curious, what does your injector harness look like ? is it set up to run 4 or 8 injectors ?
I may have a sequential box and harness sitting around.
Originally Posted by GPM
(Post 4420316)
The FAST tech line won't help, that sucks.
(Post 4420343)
I've called them multiple times.. I understand it IS a 13 year old system, but I would've thought there would be some documentation available or someone still there that is familiar with it..
(Post 4420319)
Originally Posted by 14 apache
(Post 4420315)
Thanks ! I'll give it a shot. :) |
(Post 4420319)
THANKS ! Doug 512-584-9279 |
(Post 4421047)
Your inbox is full... How much are you looking to get for it ?
THANKS ! Doug 512-584-9279 Do you need a harness? One option would be a big stuff herd they where cheep. |
You may already have this, http://www.fuelairspark.com/docs/FAS...SIC%20MAIN.pdf
Well...... It fired !!!! :evilb:
Timing was ALL over the place, have to figure that out but at least it RUNS !! https://www.youtube.com/watch?v=GDcPh-SSBYY |
Congrats !! best of luck to you !
| All times are GMT -5. The time now is 02:05 PM. |
