-   -   Merc 496 Throttle Body Cleaning (https://www.offshoreonly.com/forums/general-q/335842-merc-496-throttle-body-cleaning.html)
90profx 03-26-2016 10:01 AM
What's the detailed process for cleaning a 496 MAG Throttle body ?
Ryan00TJ 03-26-2016 07:01 PM
I pulled mine off the intake to clean the first time after buying. If careful you can reuse the gaskets. Clean toothbrush, rags and lacquer thinner or the like clean it up real nice. I would also replace the IAC muffler inside the Tb if equipped. It should be clean white foam material. If dark colored, replace. It filters air going to your
IAC valve. 496 IAC valves are problematic enough, a missing or dirty muffler only helps them die sooner. Once clean, every season clean bore and plate with clean rag and lacquer thinner. Replace or clean muffler material as needed.
90profx 03-27-2016 03:49 AM
Thanks for that info..........I'm on it as it needed this "REAL BAD"...!!
BUP 03-27-2016 03:01 PM
Is it a DTS throttle body ?
90profx 03-27-2016 05:30 PM
No sir, it's not a DTS Body.
BUP 03-29-2016 12:11 PM
Ok we just use throttle body cleaner for all NON DTS.
90profx 03-30-2016 04:10 AM
Thanks BUP, already removed and cleaning is underway....
