Bypass in oil filter.
In my 525sc I have no bypass in the block. All my oil goes to the filter. Do I want a filter with a bypass in it. I currently have a k and n 3002 filter on it.
I personally run the Mobil 1 M-302 (99% of the time) it is a high pressure oil filter. It either doesn't have a bypass or is a high spring pressure by pass. I have my blocks plugged and ALL of my oil goes through the filter. If there is an issue on my boat that plugs a filter, I have bigger issues than a plugged oil filter. I'm no expert, just 9 years of good results.
same here. Perfect place for a nickel. Fits nicely in place of bypass valve. Cheapest part on any BBC. If your filter plugs up and prevents flow your not having a good day anyway.
No bypass in filter.... K&N don't have bypasses so that's good.
No bypass in block.
I change from filter w/bypass to filter w/out bypass every other time. Keeps the engine guessing. Don't want it to think it's safe all the time.You know. like a random drug test for us humans. LOL. |
Originally Posted by Full Force
(Post 4424721)
I swore when I read up they did not, normally any HP filter does not
K&N makes them both ways.
Cool thing about Summit's website is the use of search filters. They actually have 'Filter Bypass Relief Valve' as a search filter on these: http://www.summitracing.com/search/b...ibanner=SREPD5 |
Nice. Now what's better, K&N or Wix?
Originally Posted by 79formula
(Post 4424950)
| All times are GMT -5. The time now is 02:55 PM. |
