Originally Posted by Baja Rooster
(Post 4425249)
I saw that on some generic PDF's. I was hoping that it was doable in this case.
Originally Posted by buck35
(Post 4425248)
The charger drain line , when I was researching these a couple years ago that seemed to be a concern of some that if it pukes the innerds end up in the pan.
some marine pans have a plug in the pan on #1 cyl side, mine does, what are you using now EFI or carb, EFI with blower going to be tricky at best with the merc, not saying can't be done.
Originally Posted by ezstriper
(Post 4425309)
Doing very quick research, looks like Merc #845668T (one piece rear main) has it. Also appears an aftmk't copy has it too: http://www.michiganmotorz.com/74l-82...an-p-4052.html Click pic, then click that to go thru the photos and you'll see the plug too. http://i.ebayimg.com/00/s/NDgwWDY0MA...VVP0K/$_35.JPG |
That would be sweet! I'll take a look at it later today.
This is the EFI that I was looking at. It's already set up for a blow-through situation. http://fitechefi.com/default.asp.pg-...m8-InjectorKit Using my Holley 130gph with 1/2" line from the tank to feed the fuel command center http://fitechefi.com/default.asp.pg-...lCommandCenter |
No luck on the oil pan. It'll have to dump into the valve cover.
I have a v4 on a 500efi. the earlier manuals said into the pan with an option to go into the valve cover. the later versions only say into valve cover. The 502 vortech manual I have says into the pan as option 1 and then valve cover. Same as the old 500efi manual. I think they found that the oil backed up in the hose when attached to the pan, so the later manuals are into the valve cover only. I did mine into the pan and I was getting some residue into the blower horn. I am going to change to into the valve cover.
larry |
Started getting things jigged up, and the unit is cramping the water filler neck. How is this situation normally resolved?
http://i622.photobucket.com/albums/t...36EA87236A.jpg |
you fix it with another water neck.
http://i296.photobucket.com/albums/m...ps188e455c.jpg |
Originally Posted by 272lsformula
(Post 4425686)
http://i296.photobucket.com/albums/m...ps188e455c.jpg It looks like you went with a crossover instead of the water pump? |
| All times are GMT -5. The time now is 02:48 PM. |
