-   -   PCM555 ECU memory error message (https://www.offshoreonly.com/forums/general-q/336233-pcm555-ecu-memory-error-message.html)
joketchum 04-09-2016 06:08 PM
Does anyone know what "ECU memory error" means on a PCM-555. I sent them off to get reflashed and that is the code I am getting which puts it in guardian mode. Any help would be appreciated on this
BUP 04-10-2016 10:04 AM
PCM 555 OEM version calibration, ECM Memory Fault code should be #138 which means the memory is corrupted for a fault explanation in turn means the ECM / PCM is bad. Anytime I have seen that code, 100 % of the time, the ECM / PCM was bad.
With that said, I would send it back to whomever flashed it and see what happened along a possible fix or new PCM/ECM'(s).
Trash 04-10-2016 01:44 PM
Who relfashed it?
BUP 04-10-2016 04:09 PM
for the triple nickel in the US not many can reflash this (ECM 555 / PCM 555). If I recall only possible 2 or 3 can that are not related with Motorola / Mercruiser.
joketchum 04-10-2016 08:08 PM
well the ecu's were working when I sent them off and I can put a friends stock ecu's on my boat and it runs fine, so I can only assume that it was the cal that was put on it
BUP 04-10-2016 09:16 PM
and out of the very very few who can ever recal these 555's so who did yours ????
joketchum 04-10-2016 09:27 PM
I don't want to throw any names out here, but if you know the boating industry you know who it possibly could be. I just don't understand how putting a standard performance tune that many people have could make the ECU bad now
BUP 04-11-2016 11:34 AM
I hear you and understand. IMO I am totally against sending out PCM 555 and PCM 09 and e controls to get reflashed thru the mail no matter who is doing it and the end user just plugs and plays. Totally against that form of tuning.
joketchum 04-11-2016 02:00 PM
well they are going back to get looked out. If you have a stock motor and a company develops performance calibrations for that particular stock motor, then it shouldn't be that big of an issue.
Trash 04-11-2016 03:57 PM
It could have been a bad flash and the files have incorrect parameters or memory address. I'm not sure how similar the architecture is on the 555 vs the older MEFI though.
