E85 With Flex Fuel Sensor Who Is Running It?
Just want to see who is running E85 with flex fuel sensor. And how they like it?
I run e85 and flex fuel sensor in my turboed small block street car. Works great. Where I am ethanol ranges from 70-85%.
Ditto to what he said^
Its especially nice when the pump E85 mix changes for the winter. |
Check youtube, flex fuel sensors read water as ethanol! From what that video shows they're not reading ethanol directly but rather gasoline and then assuming the rest is ethanol.
I run E85 in my avalanche maybe once a month....its a nice wake up for the truck...seems peppier but it sure burns through it A LOT quicker!
The only thing i have heard about running E85 is to make sure you are as empty as possible when switching over from gas to E85 and visa-versa and put in more then 5 gallons or the computer wont know you have switched and that's when people start having issues running their vehicles on different fuels... Around here the E85 is about .50 cheaper then regular....so for me it aint worth running E85 for less mileage.....with regular gas i get around 14mpg city driving...with E85 im running 10-11mpg... |
Originally Posted by Tractionless
(Post 4427924)
IMO there is so much misinformation about e85 on the Internet, mainly by people that have never used it. |
Found this guy / shop looking for other things.....https://www.facebook.com/DSX.Tuning
He makes an Ethanol % and Fuel Temp gauge for the GM Flex Fuel Sensors he installs / tunes to convert non flex fuel EfI cars. This guy seems pretty smart. |
So e85 is actually available at the pump? Never seen it....what's the advantage for a normal passenger vehicle? Fill up twice per week instead of once?
Originally Posted by Mr Maine
(Post 4428239)
Originally Posted by 14 apache
(Post 4428240)
How about 13to1 compression out of pump gas.
(Post 4428239)
(Post 4428297)
14 apache, don't you really need the higher compression ratio when running alcohol to compensate for the loss in fuel energy? I understand there is advantage when running modified engines for drag racing etc, but I just meant being available at the pump for a daily driver.
been racing/running E85 for years now, in a low compression, non boosted deal, no reason to use it in my opinion, now with high compression 12-1+ or boosted the stuff is great. I run 25psi+ in a LS engine no IC @1200hp right out of the pump, but yes you will burn about 40% more.
Apache are you looking at running closed loop?
Originally Posted by kvogt
(Post 4428354)
Do you plan on running only e85?
(Post 4428444)
sounds kinda tricky to try that in a boat open loop.
(Post 4428240)
Originally Posted by KAAMA
(Post 4428478)
Just an FYI, Boostane works with E85....if you have any questions just give Dave W a call.
(Post 4428464)
I run my car open loop all the time with no issues. If you have a good ecu and someone that knows how to program it, it shouldn't be an issue once you get the the tables programmed.
Apache I'm on the south Shore in Nassau if you want to see how it works. |
Originally Posted by underpsi68
(Post 4428530)
I run an Autronic SM4 (Australian).
The owner of the shop I use to dynamic my car used it on some of Zuls engines I was impressed by how when the unit works and the data logger Did you by the Holley yet? |
(Post 4428554)
The auto tune feature works great on some units. It definitely saves time.
https://youtu.be/qwkqjotkDJQ
One more thing I like about this it has 31x31 load table or 32x32 forgot. Most are not that big.
A lot of load cells are good. A good ecu can interpolate between the cells with good resolution. Here's a video of dynoing an engine using the Autronic while using only one load/rpm cell up to 9000rpm. :) https://youtu.be/vZQvB0KD5NA
(Post 4428975)
The video was designed to show the power of the Autronic and how easy it can be to get an engine up and running and very quickly tuned versus other systems. It takes less than an hour to go from non-running car, to having something that makes great power, holds consistently good A/F ratios, starts everyday when cold, and has terrific driveability without constant tweaking. We did not use any of the auto-tune features in the video. The Autronic software works differently than most others out there {including the big name brands} The Autronic software has a very complex modeling software built into the background of the software to actually predict the airflow of your engine based on a few simple parameters you put in during setup. Once the model is complete {which you never see behind the scenes} the software is so powerful that it can run your engine very well with only one single cell in the table. You can, of course have as many cells as you want{up to 512}, but what you find out is that when you are all finished tuning the engine, almost all the cells have the same number or something very close so the table looks very flat in 3D. With all other brands YOU the tuner, must create the "model" of the the engine's airflow by placing bigger or smaller numbers in the base fuel table until your 3D image looks just like the engine's airflow curve. With the Autronics doing the model for you, the base fuel table is simply used as a way for the tuner to tell the software when the engine's actual airflow doesn't match the model it created. The model is typically very accurate {as evidenced by the fact that most numbers in the base fuel table are the same or very close} How good is it at modeling the engine? Watch the video again. No tricks, no slight-of-hand, just basic math and lots of it. This video was done with a high compression N/A engine, but the software works just the same even on turbo'd cars! Using the AutoTune feature simply allows you to operate the engine in various RPM and load cells and the ECU modifies the numbers in each cell to tune the engine with no input from the user. Its really cool to watch and its amazing how fast the ECU can tune itself on the dyno, but on the street it might be easier for a good tuner to do it manually since its hard to hold a constant load and RPM. I did not under stand how the single cell worked until I read this. It uses other information to be able to pull it off. Pretty cool ECU. Same one you have? |
Yes I am running that ecu. It is a good video to show how the ecu works but honestly you need more cells. I use every cell that I can, ocd i guess lol
(Post 4428720)
Yes had it for years new in the box. Big reason I went with it was for self learning and smart coils hate the RF noise MSD gives off. Save a lot of fuel on the dyno.
Originally Posted by ezstriper
(Post 4429600)
we had the same issue with RF with MSD as well..
| All times are GMT -5. The time now is 05:42 PM. |
