will somebody please design an ignition control setup for the small cap HEI? I mean how nice would it be to be able to buy a junkyard distributor and dial in exactly the advance you want at the rpm you want?
Originally Posted by dereknkathy
(Post 4429058)
MSD has an E curve distributor, and Crane had something similar I think too.
I still think the daytona box is the way to go though |
Originally Posted by SB
(Post 4429062)
The Daytona Sensors box will do it, as I had used the Crane HI-6M to do it. Basically, you just bypass the module and use the magnetic pic up.
Originally Posted by TomZ
(Post 4428866)
So much for Mallory... owned by MSD. And no longer available.
Great... |
Originally Posted by apollard
(Post 4429799)
THe normal GM distributor you find in any junkyard will do. They were used as-is by Merc, Cruisader and others on the engines. THey have the screens for flash already installed from the factory. Then just pickup a D1965 module and you are set.
I'm going to fool with the Merc stuff tonight. If I get no joy out of it, then I'll go the Delco route. Thanks!! |
Yes, that is a module with a basic advance curve built into it. I wonder if the automotive module has any advance in limp mode? It might just...
(Post 4429817)
| All times are GMT -5. The time now is 05:13 AM. |
