QV4C Valve Lash
QV4C Valve Lash
Have a set of 1100's with 40 hours. Recently completed Mercury Racings required valve lash maintenance, no change all were within spec. This process is a major pain with a full stagger set up. Interested in thoughts on this process, overkill or just good preventive maintenance?
No btchin... do it. Valve lash is important, even more so on the high hp stuff... the valve needs time to sit on the valveseat to transfer heat out of the valve to the head... thats how the valves are cooled, also excessive lash can increase valve train wear dramatically with the high spring pressures of high output high rpm engines... granted you wont hVe the insane spring pressures like a pushrod engine but still man up an do it. If u use a remote starter control it makes it a much easier job... rm
Gary
No problem my brother, another thing to consider is now that you have a little time on the engines everything is seated in, so nothing should move around much, plus merc is hoping your going to pay out the azz to have their service dept do it and take your money for doing so. They want to see you and your money as often as possible, if they recommend 40 hours you can do it every 50 or 55 hours. Rm
Merc racing for these are the first 25 hours not 40 hours for all oils changes and the Valve lash checked and adjusted then for that end every 75 hours there on after.; This should be in your owners manual under maintenance intervals as well but not the procedure as how to.
Will add - I have not been to the current Merc racing school as of late so I really do not want to wing it per how to do all of that correctly.
IMO you should buy all the related service manuals and check for all the Service Bulletins per engine and engine serial number to help with whatever you are going to address. Not many experience people out there with these engines to count on for the advance tech help either like per say the SCI engines.
It is a good idea to check lash. If the lash starts to go away it is a warning there are problems.
I actually didn't know the QV4C had solid lifters, I just assumed they evolved to hydraulic like the rest of the world.
No idea why Merc does that. They did the same thing with the 1075s. A lot of companies will refresh the 1075s with a hydraulic roller valvetrain then its good for a couple hundred hours instead of 25...
