High performance piston rings
Wondering what most other engine builders are using and if anyone has had any issues with "total seal"? Application is for 565/700 hp NA builds.
Originally Posted by getrdunn
(Post 4433565)
Dig around in here about total seal, I remember reading to not use them. I don't remember why, but it was pretty much agreed at the time, that the are not the best choice.
Originally Posted by endeavour32
(Post 4433581)
Originally Posted by 14 apache
(Post 4433569)
Why are you asking this? Are you are having a issue?
i use them a lot,if the bore gets the hone total seal wants they seal great.imo,you can,t beat them in their price range.
Originally Posted by mike tkach
(Post 4433597)
As Mike said block must be honest. I wouldn't let a shop touch the block unless they have an RA meter. Total Seal is hands down the leader in ring technology.
Originally Posted by Black Baja
(Post 4433617)
With the said info does this create any unforeseen issues down the road. (300 plus hours). Again this is assuming block is 100% true. starting out with fresh 9.8/4.600 darts that will require machining anyway.
