-   -   Oil pressure gauge not working (https://www.offshoreonly.com/forums/general-q/336996-oil-pressure-gauge-not-working.html)
Mxer391 05-02-2016 05:07 PM
My oil pressure gauge isn't working so I'm going to replace the gauge and the sender. The boat currently has a gaffrig 2-1/16" 0-80 PSI gauge. I'm replacing it with a autometer platinum, but I only see a 0-100PSI. If I put a 0-100PSI gauge, do I need to put a 0-100PSI sender on it? Thanks
MILD THUNDER 05-02-2016 05:16 PM
Yes, you do need a 100psi sender, to match the 100psi gauge.
Mxer391 05-02-2016 05:19 PM
Thank you Mild Thunder!
Mxer391 05-02-2016 05:20 PM
Would a 98 Tantrum with stock efi502 be an electric gauge?
MILD THUNDER 05-02-2016 05:22 PM
yes. Autometer makes the correct sender for that gauge. I believe oil psi is the blue wire in the harness.
Mxer391 05-02-2016 05:24 PM
I'm ordering from CP Performance and looks like there is only one 0-100PSI sender
