-   -   Holley EFI - global file for 598 (https://www.offshoreonly.com/forums/general-q/337421-holley-efi-global-file-598-a.html)
Tinkerer 05-16-2016 09:41 PM
Anyone have a global file I can look at for a 598 NA running 8.6 compression, AFR 357 CNC heads and solid roller cam.
I am running sequential port injection.
Tinkerer 05-17-2016 07:46 PM
Ttt
launchpad475 05-18-2016 03:23 AM
PM Haxby, I bet he has something. There has to be a big NA global file in the base/custom cals that comes standard in the hefi folders that could get you going.
HaxbySpeed 05-18-2016 10:50 AM
What's your email? I'll send you one right now.
indysupra 05-18-2016 12:45 PM
Haxby is the man!!!!
Tinkerer 05-18-2016 05:19 PM
[email protected]
Thanks - I am trying to learn how to set up the global settings for this engine.
I bought the new Holley distributor with the cam sensor and crank sensor built in so that I could run sequential injection.
Thanks again.
HaxbySpeed 05-18-2016 07:03 PM
Sent. You'll have to change the ignition type, injectors if they're different, firing order, etc. but it's a solid tune that will get you up and running.
Tinkerer 05-18-2016 07:29 PM
Thanks - I am running 66 PPH injectors ( 111's) and the MSD 6 box. The cam has the 4/7 swap.
