zero effort control parts
Looking to find 4 "hook" ends to connect the throttle and shifter cables to the kiekhaefer shifter (zero effort) and also a trim switch which will attach to the shifter itself.
Thanks |
http://www.mercruiserparts.com/bam/s...32079/8457/285
Part #40 is what you are talkign about I believe - they aren't cheap for such a small part |
Yep that was it! thank you... any idea where i can a trim switch to mount on the controls?
I used parts #2 and #3 on the diagram. Then epoxied a piece of brake line on the handle to run the wires. Looks factory. no pics, but if you expand the drawing you can see how the factory ran the wires through a hole in the top of the handle and then down a tube.
| All times are GMT -5. The time now is 01:20 AM. |
