Aeromotives use the fuel to cool themselves so if they had to sat a long time and had to fight to draw fuel in you could have damaged them. Call Aeromotive...I always had good luck with dealing with them.
There great pumps if used often, when drag racing it seemed like every spring someone had one take a sh!t. Weldon would be your best replacement or put a primer pump teed to the inlet with a check valve
Originally Posted by snapmorgan
(Post 4444487)
Swap them out for some Weldon's and be done with it. I don't want to have to tow you all over Old Hickory when you come down
Originally Posted by Unlimited jd
(Post 4444499)
Turbo, they are slightly above the tanks, which I know is not the best, HOWEVER, they are mounted out in the open and very easy to get at. Otherwise, they would be mounted way down in the bilge which is probably not ideal, but I agree would help with the gravity assist. Makes sense if I fried it starving it for fuel. Probably got clogged from what I saw in the separator, then running back to the marina may have taken out the pump or damaged it. |
If you use a Weldon just use the rite size fuse. Sounds like fuel filter is plugged up happened to a friend with a 1075.
Your fuel water separator is burning the pump up. You need to put the separator after the pump. Also, it's best to mount the pump on the floor in the bildge. You shouldn't have anything but a 100 micron filter in front of the pump... Your pump is overheating and loosing its tolerances then you loose fuel pressure.
OK, I understand what you're saying.
What do you think about installing a small "lift" pump near the tank (as someone mentioned before). This would provide positive head, similar to mounting the pump on the bilge floor. Anywhere you mount the pump, it still has to "pull" the fuel out of the tank thru the pickup, so mounting the pump lower doesn't solve the issues 100%. |
Originally Posted by frickstyle
(Post 4444905)
(Post 4444905)
When I was looking at electric pumps I was going to mount it on a metal plate with slack in the hoses so that I could lower it into the bilge but pull it up easily for testing and maintenance.
| All times are GMT -5. The time now is 02:47 PM. |
