-   -   How do you stop reversion? (https://www.offshoreonly.com/forums/general-q/337967-how-do-you-stop-reversion.html)
ctuck0659 06-04-2016 06:04 PM
I have a pr. of 540's built from base Merc 502's w/ Scat stroker kits. They are otherwise built out the same as 500 efi's w/ the same Crane cam, Edelbrok Alum. heads, 500 efi intake and injection system, gil exhaust, (TRS Drives). When I built them a few years ago I bought new Gil manifolds and a used set of Gil "shorty" risers that I had extended with inner and out pipes so they were dry out to the transom and added O2 bungs. They worked with no reversion for years until they started springing leaks in the outer pipes- I guess galvanic corrosion form the previous owner not flushing in salt water so I bought 2 sets of almost-new current style BB Bravo wet exhaust risers. One engine reverted so badly the oil was saturated with water and it would hardly run. After eliminating any other possible source of a raw water leak (pressure tested the manifolds and oil cooler @ 60 lbs and the blocks are closed cooled) I had 16" of inner pipe added to keep the exhaust dry to within 3" of the tips. It still reverts big time- if I remove the O2 bungs when it's running it spits huge amounts of water out every time it fires. To make sure it was reversion I removed the water intake hose off the riser and the exhaust coming out of the bung dried out within seconds. Here's my question: I thought that mixing the water with the exhaust as far away from the engine was key but apparently not. These riser are a couple of inches shorter at their highest point than the previous set so would raising the height of the riser above the manifold with a custom machined 2" block help?
Black Baja 06-04-2016 06:16 PM
What is the rpm at idle?
ctuck0659 06-04-2016 07:09 PM
Around 750 (efi)
ctuck0659 06-04-2016 07:13 PM
Correction: It USED to be around 750. Now it's sucking so much water it barely runs at all.
NHGuy 06-04-2016 08:23 PM
I'm new to this, but it sounds like you had the solution before. You need the same or more riser height plus run.
jiffy292 06-04-2016 09:34 PM
Dry exhaust
ctuck0659 06-04-2016 10:30 PM
I hear you. But am amazed that it's a tiny bit of GRAVITY that keeps reversion from happening. It makes sense that getting the water as far as possible form the suction that happens from intake/exhaust overlap would be critical but to have it caused by at most 2" less riser height blows my mind.... I'd appreciate anybody else's input who has any experience or knowledge about this-
getrdunn 06-04-2016 10:56 PM
I hear what your saying also and sounds like you eliminated all other possibilities. So that leaves you with what did you recently change? Go back to dry or if you have the room find some of the tall anti reversion tails but you may need to make some mods cause the only ones I've seen are for bravo app. One of the two options will solve your problem. I doubt you'd wanna change cams???
SB 06-05-2016 05:19 AM
Riser height can / wll influence it big time. This is why all manufacturers have min guidelines for rate of fall for the exhaust.
Did you know when you add cubic inches, you pull more air. This means thru the exhaust during overlap too. Makes sense right ?
ctuck0659 06-05-2016 10:47 AM
Thanks for the input. I want to avoid dry because it's obnoxiously loud & I boat on a well patrolled lake. I'm thinking about having 2" spacers made out of billet aluminum to go on top of the manifolds. That would make these risers higher than the ones that were on it for 3 years without a problem. I've also still got 4" between the end of the inner pipe I added to the risers and the exhaust tips. Thinking I might add 3 more inches of pipe too.
SB 06-05-2016 11:52 AM
That is not going to change your rate of fall in the mot critical area (first 18" of riser going down) though.
SB 06-05-2016 11:58 AM
Here is what says for Merc 'black' motors.
Obviously, not modified one's.
Originally Posted by SB (Post 4441148)
If you don't have an angle finder, here is a good chart that shows how much drop in inches per foot equals certain degrees.
Slope Conversion
3° = 5/8 in./ft.
6° = 1¼ in./ft.
7° = 1‑7/16 in./ft. .
10° = 2‑1/8 in./ft. .
12° = 2½ in./ft.
14° = 2‑15/16 in./ft. .
19° = 4‑1/8 in./ft.
Min rate of fall is 6* for all Mercruiser 'black' sterndrives other than the 8.1L (496) which min is 9*.
The first 18 in. (457 mm) of exhaust hose should drop the specified minimum relative to
horizontal. Thereafter, 3° of drop or 1/2 in. (13 mm) of drop per 12 in. (305 mm) relative to
horizontal is a MINIMUM requirement for the rest of the exhaust system.
• Exhaust hoses should not restrict the flow of discharge water from the elbow. The exhaust
hose cannot be bent more than 5° relative to the exhaust elbow outlet as a hot spot
in the hose will occur and burn through.
ACrooks69 06-05-2016 11:13 PM
The water should stop reverting when you pull the O2 sensors out. That should effectively kill the vacuum signal causing the reversion. Volvo does this on some of their V8s by putting AIR check valves right near the turn in the elbow. I just wanted to share that before I say the obvious, are you sure its reversion? Not trying to irritate you, just give you a thought.
Falcon 06-05-2016 11:45 PM
"Late" timing at idle helps reduce reversion by requiring more throttle opening for the same idle rpm. This decreases intake vacuum and allows more air to be pulled from the intake during overlap instead of the exhaust. Not a cure-all, but it helps.
ctuck0659 06-06-2016 07:16 AM
So the more I research this, the more it seems to be a "black science" with lots of opinions but not a lot of absolute data or facts. SB: If I raise the point at which the exhaust starts downward by 2" and it ends up at the same exhaust tip how can that not increase the rate of fall? I mocked up a 2" spacer out of wood, so I'll calculate the fall- thanks for the chart.
As to the reversion stopping when you open the 02 bung, I've read and was told by a mechanic friend yesterday just the opposite- that any exhaust leak will make reversion much worse. The theory I guess is that by opening the exhaust path you lower the outbound pressure wave and make it easier for the water to creep back up?
I am sure it's reversion- I've pressure tested the manifolds and risers, the eng. is closed cooled, and finally I removed the water dump from one of the risers and ran the eng. for a few seconds and the reversion stopped. It was also suggested to me that I should do a leak-down test to make sure I don't have a damaged ex valve sucking the exhaust path full time. I rebuilt the engines a couple of years ago and I caught the reversion almost immediately so I doubt it but I guess I should eliminate the possibility. Thanks for the input-
SB 06-06-2016 08:13 AM
If you raise the risers with a solid, non angled spacer, the solid inner and outer pipes that turn down to go towards the transom don't change angle. They can't. Again, they are solid.
ctuck0659 06-06-2016 08:42 AM
So I put a level on top of the riser and measured the vertical drop 18" down: With the 2" spacer between the manifold and the riser base the drop was 5 3/4" (3.8"/ft) and without it's 4.25" (2.8"/ft). Without the spacer the exhaust pipe extension terminates low on the tips. The spacers make the inner exhaust pipe extension line up almost perfectly with the tips on vertical so I'm going to go ahead with that mod. It doesn't explain however why I'm getting reversion with the current set up of 2.8"/ft. of fall. However, I experienced the initial reversion before I had the inner pipes extended. When I reinstalled them after extending the pipes I checked for reversion by removing the o2 bungs, which, depending on who's right should have increased or decreased the reversion pulse. If it increased it, that would explain it. Either way the spacers make everything line up better and increase the fall so it seems like a no-brainer next step.
ctuck0659 06-06-2016 08:56 AM
SB: Well, you make a very good point. I guess I should mention another mod that I didn't bring before because I was trying not to get too bogged down in every detail. As I mentioned, the inner pipe extensions terminate too low on the tips so last week I had the (ignorant) brainstorm to raise them by having a "wedge" made by my machine shop to raise the angle enough to meet the tips. Therefore, I have plates that are 1/4" at the front, 1/2" at the back between the manifolds and risers. This raised the terminal end of the pipes perfectly but obviously flattens out the drop. Weather that's enough to explain the difference in fall I describe above I'm not sure but it must be because I measured both very carefully.
Thanks-
SB 06-06-2016 10:54 AM
Rule #1 when trying to repair anything: fix known issues first. Then go from there if need be.
SB 06-06-2016 11:14 AM
BTW, and again, those are minimum angles for Merc black motors, and notice the 8.1's min are even a greater angle.
ctuck0659 06-06-2016 12:49 PM
Understood. According to your chart, 9 deg would be in the neighborhood of 2"/ ft. I calculate mine to be 3.8"/ ft. with the spacers. BTW, what's your take of weather removing the bungs increases or decreases reversion?
