I'll put down $5 that it's the ignition. Generally speaking, electronics can work fine until strong continuous current warms them up exposing a fault, and MSD hasn't had the best track record here.
I'd open the hatch and wait the amt of time it takes you to replace the plugs. No shorter. And then try to restart and run.
plugs look dark enough. I don't know
Originally Posted by Baja Rooster
(Post 4447043)
Originally Posted by SB
(Post 4447045)
Originally Posted by 14 apache
(Post 4447038)
My money is that its not the plugs they look ok. Put a set of the old ones back in after it stalls again see if it starts.
Did the carbs get rebuilt lately? I did a dominator once put the wrong gasket in and when I shut it off it would siphon the carb dry. changed igniting on it drove me crazy.
(Post 4447080)
Thanks for the input! |
coil weak or mounted on hot motor , check ignition with fine tooth comb
Ignitions have common power source and ground? There may be something going on there. The po of my boat ran a 20g wire to the coil when it required a 12g and it was at idle that noticed a significant difference.
Have you tried changing out the brand of beer that you consume when yelling at it? I've found that to be as effective as anything else troubleshooting boat problems. |
Have you tried a different brand of plug? ( Champion RV9YC )
Originally Posted by Bill 3
(Post 4447027)
These are from the port engine. The pic in first post is the stbd.
[ATTACH=CONFIG]556164[/ATTACH][ATTACH=CONFIG]556165[/ATTACH] |
| All times are GMT -5. The time now is 01:05 PM. |
