Trim pump fluid?
Replacing trim pumps and I have had several suggestions on what to fill them with! ATF, power steering fluid, hydraulic fluid. Which is best? Thanks
It's supposed to be oil but I have a couple with ATF in them.
Atf
Pretty sure Mercury says 10-30w oil
We just had a thread on this a couple weeks ago. Pretty much boils down to your choice. Mercruiser says Mercruiser power steering and trim fluid, 10w30 or 10w40.
Others successfully use atf or power steering fluid which I use. Climate etc can play a part also. Up here in northern Michigan the lighter the better for quicker response. |
With all the comments on other thread I assure you you'll be fine with any of the above. Just don't mix
Originally Posted by getrdunn
(Post 4447711)
My pump has a sticker on it that says 20W-20 oil. Never could find it so I have 5w-20 in it. Like getrdunn said, most anything will work, just don't mix.
| All times are GMT -5. The time now is 08:27 AM. |
