-   -   Spark plug gap confusion, 502MPI (https://www.offshoreonly.com/forums/general-q/338186-spark-plug-gap-confusion-502mpi.html)
aquaforce 06-10-2016 06:49 PM
The engine plate says the MR43T plug gap is .035 but tune up info for this 1997 502MPI mag says .040 so what is right??????
The new plugs came gapped at .040. I know there are updates and new releases on information with all kinds of equipment after mfg so I wonder if there is an update where this set up is supposed to go to .040?? Anyone have current info or knowledge of why the engine plate and the tune up info say different numbers?
Also, if I change to .040 then I will have to adjust timing for the different gap I guess. What is the procedure for setting timing on this engine?
TIA
F-2 Speedy 06-10-2016 08:36 PM
no timing change, gap to .035 and go have fun
mike tkach 06-10-2016 08:47 PM
or .040.nobody will know that they are gapped at .040 except you.
F-2 Speedy 06-10-2016 09:11 PM
whats 5 thou among friends, unless were talking bearings, lifter bores ect...........lol
BenPerfected 06-10-2016 09:21 PM
DO I NEED TO SET THE GAP WHEN INSTALLING A NEW SET OF PLUGS?
A: Maybe. A spark plug part number might fit hundreds of different engines from many different manufacturers. Although the NGK factory will set the gap to a preselected setting, this may not be the right gap for your particular engine. The incorrect plug gap for your engine can contribute to a high rate of misfires, loss of power, plug fouling, poor fuel economy and accelerated plug wear. It is always best to check the gap against the manufacturer's specifications. If adjusting the gap on fine wire or precious metal plugs such as platinum or iridium, be very careful not to apply any pressure or prying force to the fine wire center electrode or insulator as they can be damaged. The gap should be adjusted by only moving the ground electrode.
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
If you have any questions, please contact the NGK Spark Plugs Tech Staff:
Tech Support - Click here
The manufacturer of your vehicle, the company that produced the aftermarket products you've used and/or your service technician are all additional sources of gapping information if you've modified your vehicle.
SB 06-11-2016 05:20 AM
.035 just buys you more time before misfire. LOL.
I set up all normal Chevy V8's with regular Delco plugs at .035" because that is what works for me.
mike tkach 06-11-2016 07:05 AM
ac delco plugs MUST be gaped at .0375 or they will misfire,lol.
SB 06-11-2016 07:10 AM
What ? Me no comprendo. Or are you joking around too ?
mike tkach 06-11-2016 07:20 AM
haha.
Black Baja 06-11-2016 07:21 AM
Just make sure there is a gap. They don't fire well when you drop a plug and the gap closes.
