Trim solenoid question???? >
Old 06-13-2016, 01:49 PM
Thanks for heads up
Tom272Baja is offline
Old 06-13-2016, 02:14 PM
Darn, I just checked.
They are in fact Sierras.....Great!!!!
Old 06-13-2016, 02:22 PM
Ok, was able to put a screw driver on the "brand new" mind you upper solenoid and it started running the outdrive up....
Uh I'm guessing I have a faulty brand new solenoid???
Or should I still consider something else?
Old 06-13-2016, 02:41 PM
try a wire between the battery + and the "pick" terminal of the " up" solenoid. If it works you have a wiring/switch problem, if not try again after adding good ground wire from battery - to the solenoid ground. Now if it works you missed a ground on the "up" solenoid. If it still fails you for bad solenoid. Good luck.
GLENAMY 242SS is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
