-   -   Sierra oilpan? (https://www.offshoreonly.com/forums/general-q/338294-sierra-oilpan.html)
INDY27 06-14-2016 08:50 AM
Sierra oilpan?
Would you use one?
Baja Rooster 06-14-2016 12:18 PM
I wouldn't use Sierra for anything critical or not easily replaceable.
bparsel1 06-14-2016 12:45 PM
^^^^^ What he said.
Sonic30ss 06-14-2016 08:16 PM
Sending two back we decided not to use them , thin gage metal not nearly as well made as factory pan.
Ended up getting Merc pans from BAM
mike tkach 06-14-2016 08:47 PM
i have not used a sierra pan but a lot of sierra parts are equil to mercury,s in quality.
272lsformula 06-14-2016 08:48 PM
Canton makes a very good oil pan.
BUP 06-14-2016 11:33 PM
some of Sierra parts are actually made for Mercruiser FYI. I will give out one example Water circ pumps Sierra makes them for Merc as well.
Some of the same parts are made side by side just stamped and boxed differently.
Some parts share nothing in common inwhich I would go with Merc.
And then there is some parts I would not even bother buying Merc. The latest coils (T bolt) are very cheap and come from China. The gear oil reservoir is total junk from Korea. This thing is a POS for the past 3 or 4 years.
I do like the Merc distributor caps and rotors.
I do like Merc impellers
IMO Merc spark plug wiress are very cheap as well.
Just a jist of it.
Sonic30ss 06-15-2016 05:34 AM
Trust me, side by side comparison, the Merc pan is much higher quality.
SB 06-15-2016 06:22 AM
Originally Posted by INDY27 (Post 4449499)
Would you use one?
GM Marine / Merc Oil Pans (stock replacement) for many Merc black motors can be found for less when sourcing from a GM Marine reseller.
See here: http://www.michiganmotorz.com/pans-c-32_156_159.html
Note: The ones that state Genuine GM Marine.
