Bleeding Air from my hydraulic steering
At the end of last season my steering was giving me trouble, it was low on fluid. I added fluid but the air was in the system. At speed the boat was all over the place. How do I bleed air from the system. Is it as simple as just working the wheel back and forth or do I have mechanic do it.....
I know, I am a bad boat owner.... : -( |
take the belt of the ps pump and spin it with a cordless drill while someone is turning the wheel lock to lock, add fluid as needed
Originally Posted by 33outlawsst
(Post 4449548)
why run the engine when you don't need to, you can spin it faster with a drill than it will turn at idle...........and yes it works well
Hmm. Interesting that you can bleed it without loosening any fittings!
any air burps back into the pump reservoir, Brad Smith showed me this years ago, and why would I doubt him ??
I once had my power stearing fail such that I could spin the steering wheel freely, round and round. I thought there may be air in the line, but to my surprise my hydrolics were pressurized...Never heard of such a thing before, but a few pounds of air and all worked perfect. Any chance you have that going on? or anyone knowing about these things know why the same systems view air in a completely opposite capacity?
(Post 4449601)
(Post 4449564)
| All times are GMT -5. The time now is 09:59 AM. |
