Testing fuel tank
I have a 1990 Formula 242ss and sometimes I notice some gas fumes in the cabin. Can someone tell me the best way to test the tank in the boat? Pressurize the tank? See if it holds pressure? If so how much pressure? Thanks for any help
3 lbs pressure
If your going to pressure test it remove the fuel from the tank first.
Is there an option other than pressure I was thinking about smoking the fuel system
do not pressurize the tank. 3 psi doesn't sound like a lot but multiply the top area of the tank by the 3 psi and see how high the side force is.
Pressurizing the tank won't work. Most are vented to allow for thermal expansion and prevent condensation.
Hydrostatic- plug vent and outlets, fill the tank until liquid is at the top of fill tube and wait...if it goes down leak
check your vent lines too they could be cracked and allowing fumes to escape |
You can pretty much bet on the tank needing replacement. It's 27 years old and, most likely, unfinished aluminum. Not trying to bust your chops, but that's going to be the case.
I have a 1977 boat and when I had it apart for stringers I decided to go ahead and replace the tank. It was corroded badly on the sides and bottom and ready to start leaking. Glad I pulled it. 700 bucks and three weeks time and I had a new tank at the door. I bought mine from Florida marine tanks. |
Originally Posted by kvogt
(Post 4450104)
Originally Posted by riverrunner242
(Post 4450099)
Originally Posted by Sonic30ss
(Post 4450124)
They make a dye that you can put in your fuel that is traced with a simple UV flashlight. I don't know if it'll work for your situation but it made it easy to spot a single drop of oil from yards away. $10 at any auto parts store.
I had a similar issue on my Pantera. I had owned it for 3-4 years. First I checked the vent hoses. Then I pulled the entire cockpit interior and floor to inspect the tank.
Couldn't find anything. Finally, I checked the fuel fill. The clamps that held the hose to fuel fill were both loose as chit and the hose had loosened up with all the vibration over the years that fumes were getting into the cabin. |
Originally Posted by vintage chromoly
(Post 4450135)
One other thing. Two years after changing the tank I noticed fumes again in the bilge, especially after filling up. It turned out ethanol destroyed the gasket for the fuel sending unit on top of the new tank. That was an easy fix and something else for you to check. |
| All times are GMT -5. The time now is 12:37 AM. |
