-   -   525 header getting hot (https://www.offshoreonly.com/forums/general-q/338377-525-header-getting-hot.html)
Rheeder218 06-16-2016 10:16 PM
Starboard motor port side header is getting a lot hotter then it should be. Put new water pumps in. Just got done putting new transom assemblies on. If I take the hose off the diverter that connect to the top of the header there is plenty of water flow. There is non to very minimal water coming out of the tail pipe. Any idea what the issue could be. Thanks in advance
Rheeder218 06-17-2016 05:54 AM
60 views no one has experienced this?
thirdchildhood 06-17-2016 06:00 AM
Partially clogged heat exchanger?
mike tkach 06-17-2016 08:39 AM
clogged tail pipe.is this on the garden hose or in the water?
moisturemissile 06-17-2016 08:47 AM
Restrictor in the tailpipe inlet plugged? Cmi headers have a drilled out pipe plug in there on the later ones.
Rheeder218 06-17-2016 09:05 AM
That was my next move is to take the exchanger cap off or back flush it.
Rheeder218 06-17-2016 09:07 AM
At the top of the header is the hose that dumps the water into the diverter/tail pipe/ muffler. If we put it in silent choice the header still stays hot.
Rheeder218 06-17-2016 09:08 AM
Is it possible that the heat exchanger could be partially plugged and not allowing enough pressure to the header? Like I said It seemed like there was plenty of water flow coming out the top of the header
Baja Rooster 06-17-2016 10:14 AM
You can grab some cheap hose and guage at any hardware store, temporarily replace the existing hose to the header with it, and check how the pressure compares with the other header. If it's high than you have blockage in the header. If it's low then it's a supply issue.
buck35 06-17-2016 10:20 AM
As mike asked is this on a garden hose? When you disconnect the jumper hose the water simply takes the path of least resistance.
