Thread lubricant, sealents and gasket tack for upper end assembly
Going to start reassembly tonight, would like to get some input on what everyone using for a few things.
1st, after mating surfaces are prepped, do I install the head Felpro MLS gaskets dry? or spray with gasket tack? 2nd, sealing off head bolt threads into the water jacket...permagasket #2? 3rd, what is used as thread lube for torquing? Antisieze? I would have ordered the ARP lube but slipped my mind 4th, intake manifold gaskets, gasket tack to hold position? How about the end gaskets...does anyone even use them? Sorry, its been 20 yrs since doing an upper end assembly and this is not a $500 small block...no option but to get it right the first time or I will be paddling it on the 4th. |
Originally Posted by JRider
(Post 4452137)
Majority of the head fasteners are studs with 12pt nuts, the only bolts through the jacket are ones that hold the jesel shaft mounts down, they are the ones that need the sealant. Hope I can source the ARP lube locally.
i would not use arp thread sealant on the bolts going into the water jacket,THEY WILL LEAK.as i said earlier,LEAK LOK is what i use and it does not leak.
Yup, looking for ARP lube not the Leak lok.
I don't remember any of the Jesel bolts going into water jackets.
Most aftermarket blocks have blind head bolt holes that won't leak around the studs
I really like Loctite 567 for a thread sealant.
Originally Posted by GPM
(Post 4452281)
| All times are GMT -5. The time now is 12:04 PM. |
