-   -   454 Mag Leak/Compression numbers (https://www.offshoreonly.com/forums/general-q/338545-454-mag-leak-compression-numbers.html)
bigredbaja 06-22-2016 06:08 PM
1998 Merc 454 Mag 296 hours where should the numbers be on compression and leak down test? Boat is a 25' Baja Outlaw if that matters.
masi242 06-22-2016 07:49 PM
I thought they were supposed to be 150.
articfriends 06-23-2016 09:29 AM
You should be in the 145 to 155 range, leakdown should be 30% or less
