2004 Merc 575 warning siren won't go away
It has 76 lbs oil pressure, 110 oil temp and 140 water temp . 30 psi fuel pressure runs great. Just all of a sudden it stays on?? any Ideas
all I did is replace fuel lines on the throttle body.. ( on both engines)
Mine had the same problem, it was a wet oil pressure sensor, a different one than the gauge uses.
Im assuming their efi ? if so fuel pressure seems low for, should be in the low 40's, are they bravo drives ?? drive reservoir low ? solid tone or interupted
It sounds like intermittent and solid both cause it changes a little art first. It only comes on after the high idle . It does not come on in the first 10 seconds or so. It will not go away at any rpm. Maybe it is a sensor for low pressure like J rider said? Unhooked the drive reservoir sensor wires and it's half full too.
what sensors does it have that set that off? I would think oil pressure for sure, water temp for sure . it there more than that to check?
That's a make switch on the drive bottle, when unhooked the circuit is open and will alarm, did you hook the wires together to close the loop
Originally Posted by 33outlawsst
(Post 4459890)
. I will try it |
(Post 4459866)
Originally Posted by mcprodesign
(Post 4459925)
That's what I thought . Thank you. The guy at the dock was telling me it was the other way
. I will try it |
| All times are GMT -5. The time now is 09:48 AM. |
