Codes 42 and 43 on 502 MAG MPI. 1995 SN OF764XXX
Original sea trial was 68mph in VA. Next weekend in New Orleans, only ran 65. Oddly enough, she couldnt spin the 25m+ that came on her down here!, but ended up labbing a set of 24p B1s. Consistently ran 62-63 loaded and 65 light in spring with just me.
Then when I had issue wiht SB motor where I lost rpms after 40 miles across lake coming back from tickfaw 200 and came to idle, she revved fine, so she recovered and ran 67.4 was odd. I changed TPS on SB then found codes on P motor, replaced Map and Knock, rerouted knock wire as it was running between plug wires and codes didnt come back.
Before, codes 33, 42 adn 43 would pop when I cranked only. If I cleared while idling, it would not throw codes. I started several times and ran for about 15 mins on hose and didnt throw any codes again.
So now, neither engine has or is throwing codes. I do not know how long the codes were on there.
SB codes never reappeared once cleared, but P did, which I changed map first with no affect. Paperwork from dealer that changed engines lists new map, but didnt specify which engine with new long blocks. (80 hours)
Once I changed knock, codes would not come back.....
So, its kind of wierd that I ran up to 67 when down here, she never ran more than 63 loaded before. Odd...
