How to cannect throttle shift cables To zero effort morse controls
hello I am switching out my quicksilver throttle to a zero effort morse throttle shift levers. I cant seem to find any info on the levers. The cables don't seem to have the same hook up as the old one. Does anyone know were I can get some diagrams or something to see if I'm missing linkage or something. or do I need different cables? has any one done this type of swap before any help would be appreciated thanks
you must use the later merc cables or morse 33c type and there is a adapter kit for the connections, CP performance has what you need
yep 33C it is and turns out I have the little plastic adapter that the nut goes in to attach the cable to throttle and shift levers. then a plastic kit for the engine side (red). ordered the cables and should be GTG! thanks for the help
| All times are GMT -5. The time now is 05:04 PM. |
