What height should K planes be above the running surface. Pro and con for dif heights
Installing the K plane on Scarab 33 AVS after new transom. They are at the same angle as the hull (angled) What height should K planes be above the running surface?
What are the Pro and con for different heights. |
Mine are just shy of 1" above the running surface
Mine are 3/4
Hmm, I thought 1/2" was standard?
3/4 min. Mark them out. Double check inside. Make sure nothing is in the way for thru bolting and hose locations. Bottom thickness also has to be watched
| All times are GMT -5. The time now is 07:01 PM. |
