-   -   Sea Strainer question Bravo Hose size? (https://www.offshoreonly.com/forums/general-q/340082-sea-strainer-question-bravo-hose-size.html)
mallatt442 08-08-2016 01:15 PM
Need to install a sea strainer and need advice (help) as I am out of town working. What size is the hose coming from the drive to the sea water pump? 2000 year 502 MPI-Bravo 1
When choosing a strainer, what size inlets should I look for? I know the fitting will need to match hose size but don't want to restrict water flow. Any help will be appreciated.
Thanks, Mike
getrdunn 08-08-2016 01:32 PM
Mike
I've only seen 1 1/4" on most everything.
getrdunn 08-08-2016 01:36 PM
Most sea strainers that don't have a fixed slip/barbed fitting will all for the most part have 1" or 1 1/4" npt.
Baja Rooster 08-08-2016 01:42 PM
The hose is 1-1/4".
mallatt442 08-08-2016 03:53 PM
Thanks gang! The hose size was my first concern to get the proper fittings when I order.
Tractionless 08-14-2016 09:22 AM
Which strainer are you going with?
