Blind mounting swim ladder? - 89 Baja 226 Islander
Hi,
First post :) I recently purchased an 89 Baja 226 Islander 226 open bow and I would like to mount a swim ladder under the integrated swim platform. I do not see any viable way to back up mounting hardware, as it does not appear I can access the ~6" deep cavity between the top of the platform and the bottom. i have seen others with this model with a swim ladder via online photos when researching, but I cannot tell how they are mounted. From research (and common sense) I am assuming all types of screws cannot be used, but I did find a product called blind fasteners, but I don't know how well I would be able to seal the installation to prevent water intrusion. I am a rookie, so am I missing something? Any suggestions or advice would be greatly appreciated. Thank you, Joseph |
I installed a aquastep ladder under my Fountain a few years ago and it came with all the hardware. If you use a 3M marine sealant and do what they call a wet installation of the hardware you should be fine.
Originally Posted by ProblemSolved89
(Post 4470684)
Hi,
https://www.amazon.com/gp/aw/d/B0000...=1&pc_redir=T1
These Garelick fasteners/bolts have been discussed on here for mounting bolsters and heads. I think this could work for you guys. They are available in stainless steel. |
Thanks, may be worth a try.
Originally Posted by Tractionless
(Post 4470977)
http://www.offshoreonly.com/forums/f...s-how-fix.html http://www.offshoreonly.com/forums/f...rew-holes.html |
Originally Posted by Sydwayz
(Post 4471028)
Was on my phone yesterday. Here are some previous threads now that I can find them easier:
http://www.offshoreonly.com/forums/f...s-how-fix.html http://www.offshoreonly.com/forums/f...rew-holes.html Joseph |
| All times are GMT -5. The time now is 06:59 AM. |
