drive swap alpha 1 gen 2 to bravo one
what would i need to go from a alpha to bravo 1 its on a baja hot shot i swapped out the 4.3 to a 5.7 the alpha had a 1.8 ratio i figure i would be better off buying a used bravo 1.5 than changing the gears in my alpha
Originally Posted by mira boater
(Post 4470815)
Stay with an Alfalfa.
350 keep the alpha. Used alphas are everywhere.
Originally Posted by I.C.U.Lookin
(Post 4470941)
Yup, maybe they will come out with a Bravo upper soon.
http://www.sterndrive.cc/Mercruiser-Sterndrive.html |
Thanks for the help I will look for an alpha with a 1.5 ratio
Also, the gear change is done in the upper so that is all you need if you find one. The SEI one is 750$ new.
| All times are GMT -5. The time now is 01:21 AM. |
