-   -   Heat exchanger help (https://www.offshoreonly.com/forums/general-q/340353-heat-exchanger-help.html)
JaySoCal 08-15-2016 10:38 PM
Heat exchanger help
Re-powering a 89 25' marlin cuddy cabin I just picked up. Going to convert it to efi using a chevy 4.8l ls about 20 more horsepower and 30 lbs more torque than the 5.7 that was in it but shouldn't kill the alpha 1 gen2 that's on it. Trying to decide what heat exchanger size wise will work. This if my first off shore boat all other boats I've had where river/lake boats. Any help or ideas would be great.
ezstriper 08-16-2016 06:04 AM
there is a place in NY that sells aftermarket units at decent prices, been using a pair for well over 10 years now, can't remember name right off google it...something cool I think, going to be a $$$$ swap because of all the special parts required
JaySoCal 08-16-2016 08:59 AM
I'm going to document the swap shouldn't be to bad price wise think I should be able to do it for 4k or less and have fuel injection keep the same cruise speed the boat had and use less fuel.
park35 08-16-2016 09:16 AM
Lenco in amityville ny.....he will make you what ever you want and can size it for you
ezstriper 08-17-2016 08:08 AM
the manifolds, raw water/alt pump setup are $$$$ good luck...several have been done
JaySoCal 08-17-2016 09:02 AM
Manifolds are 250 each risers are 170 ish if mine won't work on those manifolds. Starter and alternator have a friend that can rebuild the stock units to cost gaurd spec. Working on a Re-power with a heat exchanger to sell for carb 350 to efi swap for around 5k
