Power steering pump fitting Aeroquip?
Where can I get this fitting on the back of the pump? I was going over the fittings on my new project and I don't believe this to be safe.
http://i43.photobucket.com/albums/e3...820_175628.jpg . http://i43.photobucket.com/albums/e3...820_183839.jpg |
rookie,i believe that is from latham marine.it uses a high pressure hose good to 3000 lbs if i remember correctly.
http://www.speedwaymotors.com/Steel-...-GM,37128.html
This is what I used, not sure why CP is saying they are 5/8 threads mine were 16mm. Looks like if its a old pump then they us 5/8 https://www.summitracing.com/parts/tff-5553a Here is one from summit for 15 bucks Any good hydraulic shop can make you up a hose, I usally use NAPA. |
TTT
Thanks for the responses, but I'm looking for the actual fitting, not an adapter end. |
Originally Posted by Rookie
(Post 4473595)
TTT
I'd just run it. Looks fine.
Update,
Local hydraulic shop that carries Aeroquip had the reusable fitting in -6 so I just cut and crimped a -6 to an old steering line that I had laying around. Approximately $15 for the repair. Thanks everyone. http://i43.photobucket.com/albums/e3...824_172136.jpg |
That looks so nice maybe you should change out the other fitting :-)
| All times are GMT -5. The time now is 04:37 PM. |
