How much timing advance should I run?
Not sure what I should be setting my spark timing to?
The motor is a replica of a Haxby "EFI for everyone" Gen 6 454 Mag Standard Iron heads with Inconel Valves Holley Terminator TBi EFi on a Victor Jr intake Eickert Alloy headers with dry to the tip tails Bob Madara custom hydraulic roller cam and full valve train I am tuning it in the boat with the Holley software on a laptop and despite the dry exhaust reversion kills O2 sensors for a living so my tuning windows are fairly small. It sounds good but doesn't pull nearly as well as I hoped so I wonder if I am conservative on the tune My target AFR is 12.2-12.5 at WOT I have been using 32 degrees of timing and today tried advancing it out to 36 degrees, it seemed to run a little stronger but I am worried that may be way to much and I could do some damage? |
34-36° will be fine.
What was the performance gain over previous setup? I agree with Sutphen, 34-36 should be fine.
Are you in the rpm range at wot you should be? |
Opinions are mixed but for the most part people have had good results using one of these on their O2 sensor to make them live longer.
http://i622.photobucket.com/albums/t...2060A1E833.png |
If you have dry exhaust and reversion is killing the O2 sensors you may have other problems. I've been running wet exhaust for over 6 years with continuous wideband use. May be something to look into.
had same issue, tried a few extenders and filter no luck, moved the 02 to #5 header tube 10" from flange worked fine
I am running lightning headers wet with the inner collector extended 2 inches and a 525 cam. My O2 sensor lasted 2 seasons. Put mufflers on this year and killed it within 5 minutes.
You can watch the knock channel on the Holley for any Pre ignition if you have a knock sensor hooked up |
Did you Dyno setup at all?
36* would be what I set it too with GM heads. 32-34* with a good set of heads.
call haxby,if your engine is a copy of his he should have the answer you are looking for.
You have a 2D timing table at your disposal - based on load and RPM. Take a look at some of the examples in the Holley supplied global folders to get an idea.
Cams probably too small.
| All times are GMT -5. The time now is 12:18 PM. |
