-   -   Driving thru chine walk (https://www.offshoreonly.com/forums/general-q/341150-driving-thru-chine-walk.html)
kvogt 09-15-2016 02:06 PM
I don't know if it was already mentioned but check your toe in or out on the drives while it on the trailer.
getrdunn 09-15-2016 02:42 PM
Good point for everyone to check every now and then. Wonder if props are spinning in or out?
zz28zz 09-15-2016 08:09 PM
Toe-in is neutral and the modified Mirage props are spinning out.
KRAUSMOTORSPORTS 09-15-2016 08:49 PM
Nose cones? Not that I don't think that would do anything about chine but could change a lot in driving characteristics
zz28zz 09-16-2016 01:06 AM
No nose cones. Still running the original drives from 1990.
ezstriper 09-16-2016 06:05 AM
Originally Posted by mcprodesign (Post 4481332)
A twin engine fountain should not chine walk . Check trim indicaters to make sure the trim is right at wot possition. If it porposes use trim tabs to kill it . You may gave to trim pretty high to get it to stop moving around . Sometimes fuel slosh causes problems . Check drive alignment too. Mine does not like the dtives trimmed down
I'm guessing you have never been in a twin BB 29 then
mcprodesign 09-16-2016 05:39 PM
Naw just a 27 that chine walked a bit and my 38 that only chine walks when somethings wrong . I'm only trying to give all i know . Did all the 29's chine walk ?
phragle 09-16-2016 05:56 PM
I really think the question that should be asked is what can be done to eliminate chine walk, not drive thru it,
Sure, your always going to get an occasional wobble, but if a boat or a series of chine walks most of the time, there is a hydrodynamic instability.
If your truck got severe speed wobbles at 60 mph all the time, would your answer be to let your family pucker while you death grip the wheel and try and drive thru it or would it be at the shop to figure out whats wrong?
MINK 09-16-2016 09:47 PM
I thought most fountains spun the props in?
Tinkerer 09-16-2016 10:08 PM
One thing about proper set up is NO ill handling. My daytona would porpoise at mid range speeds. It no longer does at ANY speed.
mcprodesign 09-17-2016 01:20 AM
Maybe if he spun them in , it would carry the nose a bit and kill the chine walk . Or it might get worse ??
zz28zz 09-17-2016 04:07 AM
I know a ex Fountain race driver who once said all padded bottom deep V's will chine walk (if the driver doesn't stop it) and hull length is the main factor determining what speed it happens. The longer the boat, the higher the speed it starts to walk. He went on to say that chine walk is the drivers inability to balance the boat once it's on the pad.
ezstriper 09-19-2016 08:23 AM
most all, if ran mid 70's and up, ran a friends twin BB several times at the potomac river radar, low 80's boat that would scare the crap out of you at any given time. Fountain actually dropped the twin BB option on the last few years of production, singles were no better with big power
ThisIsLivin 09-19-2016 08:58 AM
I hit chine walk in my Velocity about 85. I talked to Steve Stepp and he said driving through chine walk is like driving your car on ice, you turn into it with small quick corrections.
rak rua 09-19-2016 09:15 AM
Just to make you feel better, anyone can have problems with high speed boat handling no matter how experienced you are or how much you spend....
‘That boat was set to do 70 knots, but we could never get it to steer over 66 knots – as soon as it got to 65, 66 knots, it would either spin out to the right or the left. It was a massive spin-out, like being in a WaveRunner. We never ran that boat over 90 per cent power.’
(John Staluppi talking about his 42m superyacht 'The World Is Not Enough')
He then continued to say....
"Imagine what it’s like to wipe out in a 42m superyacht at just short of 70 knots. Staluppi admits it was ‘Very scary’. But even short of maximum power, The World Is Not Enough is a very impressive motor yacht"
source: http://johnstaluppi.com/john-staluppi-yachts.html
If he had trouble getting it right, I guess it can happen to anyone.:)
RR
mcprodesign 09-19-2016 10:01 AM
Yes thats counter steering . Anyone that ever drove a fast v outboard has to be good at it . Fast meaning ; whipping the steering wheel back and fourth . The boat cat walks side to side but the boat remains level and the nose hangs high. A fountain like my 27 was like this a bit .
mcprodesign 09-19-2016 10:18 AM
Here is a hydrostream set up perfectly so he needs very little countersteer to get to speed. Watch closely just after 1:30 and you will see him chop the wheel like i was trying to explain. Sometimes if the boat is not right you will have to rapidly do the steering wheel chop back and fourth. I had a 17 ' switzer with a 235 on it that was almost impossible to run because it was nasty chinewalking . I had a 18' with a 200 that was not as bad but if you let off the throttle entirely, it would flop on to the left side . Thats how you get through a chinwalk. Dont let off quick if you cant make it because that might make you crash :)
https://youtu.be/8wmky9SuaJg
mcprodesign 09-19-2016 10:42 AM
https://youtu.be/rL4bsYFQtN0
mcprodesign 09-19-2016 11:07 AM
Here you see a ol 29. Very very little chinewalking . Requires a very small amount if countersteer. But watch close. On a small scale. This is how you do it . Good luck! I still say work on set up though . Chad
https://youtu.be/IjwQ28sWGpI
