-   -   1075 sc cam in a 565 NA build (https://www.offshoreonly.com/forums/general-q/341174-1075-sc-cam-565-na-build.html)
getrdunn 09-12-2016 05:46 PM
Anyone use this cam in a 555/572 NA build. Specs are 252/257-673/673 on a 112? If so I'd appreciate your comments.
Thanks,
John
14 apache 09-12-2016 06:26 PM
It does not have distributer gear or a fuel pump lobe. Specs look like 900sc or close.
getrdunn 09-12-2016 07:04 PM
One of the members here was kind enough to send me a Bullet Racing Cams cam card that was taylored from the 1075 sc. I knew about the fuel pump lobe but never gave the dist gear a thought.
sutphen 30 09-12-2016 07:14 PM
I'm sure bullet could add the distr. gear.honestly,I'd want 8-10° split bewt in. and ex. duration.
getrdunn 09-12-2016 07:17 PM
1 Attachment(s)
here is an old thread and post from Bob m showing specs. No sure what specs I posted are for if this holds true.
getrdunn 09-12-2016 07:27 PM
Gear is on this particular grind from bullet.
