-   -   props (https://www.offshoreonly.com/forums/general-q/34195-props.html)
jafo272 10-03-2002 10:51 AM
props
I'm running 272 baja with 496 HO, 23 mirage plus @ 5100rpm and 68mph, tried 25 mirage plus @ 4600rpm and 65mph.
Had the 25 turned too 24 and labbed @ easy 5100 and 66mph. any suggestions would be great. WOT says 4600-5100. Im hitting rev now and the with the 23
Thanks JAFO272
fountain27ho496 10-03-2002 11:39 AM
should be 4600-5000
I have the same motor, says 5000, thats why your
hitting the rev, I was spinning 5200 the other day
and didnt hit it ? Usually 68 on gaffrig speedo with
26 bravo 4 blade, what drive? I have a new 25 ballistic
3 blade I cant use because of xz, larger shaft.
mopower 10-03-2002 01:59 PM
I had real good luck with Ballistics. They have a much thinner blade than a Mirage and takes less to turn them , giving you more to use:cool: Sorta like a labbed prop from the factory:D
jafo272 10-03-2002 03:59 PM
fountain: I dont understand if 5000 is right how are you running 5200 with no rev? The 24 is labbed by throttle-up and im running a bravo x
baja272 10-04-2002 10:42 AM
jafo272
Have the same boat, a 94 272 with a 502mpi. Started with a 23 mirage and was able to attain 66 mph at 5100-5200rpm. Went through the prop testing through a mercury demo shop. Tried all pitches and 3 and 4 blade props. The best for me was the 24" 4 blade. I gained 2 mph and lowered my RPM to 4800-4900. The 4 blade is 10 times better out of the hole and is much more efficient at around 40 - 50 mph. I tried a 26" four blade but was only able to get to 65 mph and 4500 rpm.
The 4 blade will bite pretty hard and you may have to muscle the boat a little especially at top end, however you may like it!!
