-   -   Motor Issue WOT 4000RPM (https://www.offshoreonly.com/forums/general-q/341951-motor-issue-wot-4000rpm.html)
phragle 10-15-2016 06:00 AM
try a 23p
Baja Rooster 10-15-2016 12:29 PM
Originally Posted by 88Rocket (Post 4491368)
used the factory wires for the distributor hmm I wonder.it has a cheap fuel pressure gauge that was on it when I got the boat If I remember it does drop when we were tuning it upbut don't remember how much . it has the stock block side fuel pump . you can see it in the pics I think.
I put a 502 crate motor in my 272 and could barely get it to 4800 with a 23p M+ and 50mph. I changed the 22g wire to my DUI to the required 12g, straightened out a small kink in the fuel line between the separator and fuel pump and got 5k with a 25p M+ and 58mph. Then I changed the secondary jets from 88 to 84 and and got another 500 RPM and 63mph. You may have improved hardware but the performance is all in the details.
johnny b good 10-17-2016 11:59 AM
I had an 89’ Sunsation Rocket with the stock 330hp 454 Q-jet and Bravo 1 drive, and that boat would do 62-63mph on gps. I can't remember the prop on it though.
airjunky 10-20-2016 12:00 PM
I have seen 049's with more chamber volume than some 188's and 088 mag heads .if you slap them on a block with flat top pistons its likely going to be sub par even with razor thin head gaskets
88Rocket 10-21-2016 11:04 AM
got the prop reworked
Before
https://lh3.googleusercontent.com/tX...S=w526-h934-no
after
https://lh3.googleusercontent.com/y7...0=w526-h934-no
