Weren't 500 efi heads just 088s? You can find them in swap shop or pbss. I sold 2 sets this year. Expect to pay around 1k for a bolt on ready set
Originally Posted by I.C.U.Lookin
(Post 4512356)
Originally Posted by Griff
(Post 4512343)
Probably Jegs or Summit
12562925 / 12562934 Service replacement head for Gen V / VI block with 7/16 accessory holes |
Originally Posted by sutphen 30
(Post 4512361)
you want this one
934 is the same as 088.
Originally Posted by 1MOSES1
(Post 4512364)
Thanks sutphen. I just found one at summit. Problem is the 2.25 vs 2.18 valve stem area. Can this be machined? I wanna re-use valves.
Originally Posted by getrdunn
(Post 4499571)
Just so slightly tapered. Only one way out. If you have a good head guy he will do his best and. Cam go oversize etc. Just wonder if there is type of sealer or coating to help while installing new. Little to no clearance makes this nearly impossible but just thinking outloud.
These kind of problems eat away at me. Didn't do it before and does now type of thing. Both engines. ??? Drives a guy crazy. fall in , I have a mandrel that I insert in them and tap in with a ballpeen. They make product called Fluid Weld , I get mine from Goodson , stuff works great , couple drops on the guide and drive it in . |
Originally Posted by dunnitagain
(Post 4512406)
Dont reuse your valves with new replacement heads ...... False Economy.
(Post 4512364)
i don,t want to sound like a debby downer BUT,if one engine needs replacement heads,why not the engine next to it that runs the same amount of hours in the same water.
| All times are GMT -5. The time now is 09:15 AM. |
