-   -   Colapsed Lifter? (https://www.offshoreonly.com/forums/general-q/34247-colapsed-lifter.html)
ALFSTER 10-04-2002 09:27 AM
THRILLSEEKER
Did you find out what the problem is?
THRILLSEEKER 10-04-2002 09:39 AM
Alfster, not yet, Tonight I will pull off the intake manifold and check the lifter. I hope to hell its not a cam lobe. If it is I will have to pull my outdrive off just to get the engine out to change the cam:(
ALFSTER 10-04-2002 10:10 AM
You must not have enough room to get engine out with drive on that sux.:mad: If you have a roller it may have broken the axle on the lifter.If you have a flat tappet its probably the lobe,and then you can send it to me and I'll throw it in the pile of lunati"s I have with #8 exhaust lobe gone.:eek:
formula31 10-04-2002 11:58 AM
Man I dont know if I would start ripping an engine apart at this time of year because of a hot tick. Its not that unusual on these older engines. You have Tempests in there dont you? Was the tick still there with it cold? Were you able to find which one it is? Its usually just a sticking lifter and chaging the preload a little can cure it. Wear could have removed almost all the preload and when it is hot there is none and the tick you hear may just be from no preload.
Just some thoughts.
I hope Kellys tomorow if I get mine finished in time.
Tom
THRILLSEEKER 10-04-2002 12:40 PM
Tom, The engine ticked when it was cold then after it warmed up the noise got louder. I pulled the valve cover off and all of the rocker arms were tight but there was lots of slop in one rod so I pulled the rod out and it was straight:confused: so now I am going to check the lifter. Have fun on the island this weekend.
Tony
