-   -   how much power can stainless marine take (https://www.offshoreonly.com/forums/general-q/342935-how-much-power-can-stainless-marine-take.html)
DiamondPerformance 01-17-2017 09:51 PM
1 Attachment(s)
Fountain did a test years ago -
MILD THUNDER 01-17-2017 10:02 PM
It be nice to see that test done, on an engine that actually has some overlap, and turns some rpm. I think your product will really shine there, as opposed to a low rpm 500hp minimal overlap cam
SB 01-17-2017 10:05 PM
Originally Posted by MILD THUNDER (Post 4520394)
According to pipemax, a build like that maxing at 6000 rpm, making 750ish hp
For low to mid range power, a 2.06 to 2.131 diameter primary, with 18.8 inch x 3.829 to 4.079 diameter collector.
For mid to upper rpm power, a 2.206 to 2.331 diameter primary, with 18.8 inch x 4.079 to 4.579 diameter collector.
Thats a mile, wait, 10 miles, away from a typical stainless marine standard manifold. In the car world, if you stuffed a 750hp 572ci big block in your car, and ran a 1 7/8" shorty header, with a 3" inch collector, someone would smack you across the cheek. :cartman:
I believe MER Performance recently dynoed a 650ish hp 509 build. Made close to 640 with the 2.25 dyno headers. Bolting the stainless marine manfolds on, it made right about 600hp, and lost a bunch of torque as well. About 30ft lbs I think at peak tq .
Collector length means a ton ! Max hp doesn;t really change, but if you would see the torque and hp difference's from mid to upper mid rpm you may schit yourself - especially between worst lengths and best lengths.
getrdunn 01-17-2017 10:13 PM
Originally Posted by endeavour32 (Post 4520427)
Let me know when you guys plan to dyno. If I can just give them to you, that would be the best!
Just keep your Gil's... Might just keep you from getting t-boned. Remember house sold. GC next. Don't fk with me. Lol. Just kidding. I think those exhaust are awesome not only power but looks. See them in person and they grow on you real quick. They look even better in a twin app. Did you ck measurements yet. Warm this weekend.
endeavour32 01-18-2017 07:15 AM
I'm coming up this weekend. I need to pull my drives and if possible, pull the other 3 Gil manifolds.
KAAMA 03-05-2017 01:27 PM
Endeavour32, call me if you get a chance, for some reason I cannot send out a PM
