-   -   Pro comp bbc intake min CSA vs 454r min CSA and minimum to maximum differences (https://www.offshoreonly.com/forums/general-q/343019-pro-comp-bbc-intake-min-csa-vs-454r-min-csa-minimum-maximum-differences.html)
articfriends 11-30-2016 03:13 PM
Bought a pro-comp intake set up for efi with rails, 170$ off ebay, did this to test on a upcoming dyno project, even AFTER reading they have core shift, dont line up, mediocre, etc. On initial inspection and trial fitting to engione to check angles/ overlay gaskets on to check port opening alignment I was quite surprised it lined up real well. fit real well, no core shift I could see, they actually claim there molds are better than the ones that have been used by edelbrock and other company's for years. Delved further into it when I started port matching it and checking minimum CSA and found that #2 and #7 ports were 10% smaller than the rest (1/2 way in at bend), if ports were a true rectangle for discussion lets just call it square inches, so my tight ports were about 3.45ish, my average ports were 3.7 to 3.85, I worked on #2 and #7 until they were in that 3.7- 3.750 range.
Fast forward, in discussion with a couple other guys that do this the question comes up, was it a ****ty casting, was the 454r that I assume this is a copy of a flawed so the copy is also flawed or was this done on purpose for some reason? Last night Gimmefuel brought over his used edelbrock 454r, has had slight port matching done but nothing done to check or adjust the minimum CSA/square inches, any guess on how they compared? Is having a pinch point halfway thru intake runner thats 10% small in 2 runners a big deal? Going to find out on the dyno fairly soon!
MILD THUNDER 11-30-2016 04:39 PM
Good info Smitty !
Gimme Fuel 11-30-2016 05:09 PM
This is going to be an interesting test for sure.Can't wait to see the results. Would be interesting to get another box stock chineseium intake and compare modified to as cast back to back.
articfriends 11-30-2016 05:42 PM
So back to this as I have time to finish typing this out, on examination the edelbrock 454r has Minimum CSA in biggest runner of 4.34 sq inches and smallest is 3.40 square inches, only 27.5 % DIFFERENCE best to worst and the average ones which still varied more than the Chinesium intake were around 3.80 but we had some at 3.68, one at 4.2 besides the other big one, some around 3.75 to 3.8, NOT IMPRESSED. If you ground on the edelbrock enough to even them up it would be HUGE, I dont think youd want to hand grind a port 27% bigger anyways. How important is a difference from cylinder to cylinder, I thought 10% was bad but I guess I could accept that now as ok, 27 isnt in the ballpark. Will the 454r outpower the chinesium, with its two "extra big" ports, I doubt it, well see, if anything the afr's will be farther apart cylinder to cylinder, unless, this was done on purpose (I highly doubt)
getrdunn 11-30-2016 06:24 PM
Your last sentence caught my attention. "Purpose". Who knows why they do what they do when what we think would be right would be so easy for them to mold without being exact as American. Or at the the very least make some sense as to why!!! They certainly get those little rice grinders moving in fast and furious but it always seems vin diesel and his crew have to go over to get the American muscle to compete. Just a guess vins using American muscle parts.
Btw you ever ck darts? They surprised me originally however there is some method to the madness. I've yet to see a bolt on intake make any power.
SB 11-30-2016 06:25 PM
:cartman:
This carb spacer will get'r done :)
https://www.youtube.com/watch?v=9EwN8HjoYgE
SB 11-30-2016 06:31 PM
Again Smitty biggest gains are up top = Inlet to runners...and those tight corners (usually inner 4 runners) need to be made more gradual...keep it nice and gradual. Finish with 80 or so grit..... :)
Most of your airflow is up top of runner and usually the farthest wall.
Black Baja 11-30-2016 07:03 PM
You don't compare port to port. You have to look at the whole port all the way to the valve. Port length needs to be considered as well. Size the port on the intake side to work with the head. Also, if you have a rectangle port you don't count the corners when calculating CSA. Air doesn't flow in the corners.
articfriends 11-30-2016 09:19 PM
I think the edelbrock that is so far apart from best to worse is sand cast in socal or mexico
NDH2O 11-30-2016 09:19 PM
Good info, I'm curious to see the results. I'm doing a similar combo 540 with a Holley dominator efi. What's your expected peak hp rpm?
articfriends 11-30-2016 09:40 PM
But simply out of the box, IF you have a production intake and your looking for choke points and find a couple ports with a csa 27% smaller , without a flow bench or getting real scientific you wouldnt tend to believe this was for a reason?
As far as CSA vs square inches, yes, in first post thats why i said for discussion lets just use square inches, if you calculate act cross sectional area the percentages dont change.
Biggest thing is i was surprised to find pinch points 1.28 wide and others at 1.500+ both having close to the same port height.
SB 11-30-2016 11:06 PM
In a perfect world, the runners would taper. Biggest size at port entry, smallest at exit. If airspeed is going to be real high going into a sharp corner, the area just before may be enlarged a little to slow down the air at that point to help it make it around the corner....but, that is flowbench stuff. Just keep it in the back of your head.
And if going for a target CSA, remember you do have to measure it with your equipment accurately. Tough with just calipers, If there is a decent radius in the wall/roof/floor corners, it will have to be accounted for. If it is sharp, like Black Baja is mentioning, then it doesn't.
I wouldn't kill yourself on this intake project like with the MPI's as a carbed intake is not dealing with strong 2nd or 3rd harmonic tuned lengths like MPI (Tuned Port) intakes. Just a little work will go a long way.
articfriends 11-30-2016 11:24 PM
Scott, im not going to grind on the 454r at all, its a borrowed intake, the difference between tightest to biggest minimum csa is so severe i would have to spend 50 hours straightening it out. The chinesium intake, much more uniform, did sll the modding to it im going.
As far as measuring the pinch points in the ports, aside from casting molds in each one , no its not super accurate using inside calipers but i do try to consistently do it and slso use a mean average, Smitty
ezstriper 12-01-2016 08:25 AM
We ran a carb version of that intake a few years ago in street/race car did for one of my sons, never did and dyno test, did do quite a bit of port matching and it was a oval using 781 heads, car ran faster than we thought it should. On the flip side, just got a victor jr for LS project I'm doing for my other son, casting was pretty damn rough on the edelbrock(did say USA) again did quite a bit of port clean up on this as well as using GMPP CNC ported heads. So bottom line is edelbrock seems to be the best intake out there at this point, still edgy on casting, the chinese stuff is really bad from what I have seen, but how much diff in power ????? thanks Smitty for all your testing/reporting
bck 12-01-2016 09:50 AM
Does anyone still use the extrude hone process? Seems like a good application for it.
articfriends 12-01-2016 11:05 AM
In this case the procomp hsd a better finish and much more consistent ports so we will see, i dont think the 454r having 2 huge ports vs the other ones that are all over the map and same size as the procomp is going to make it work better somehow
