-   -   Silicone hose for exhaust? (https://www.offshoreonly.com/forums/general-q/343089-silicone-hose-exhaust.html)
splashandburn 12-04-2016 04:35 PM
Anyone ever used 4" silicone hose to connect to tailpipes? Much more flexible and easier to install than the stiff rubber boots. Rated @ 500* F and 275 psi burst pressure. I've had issues trying to seal the rubber boots and thought this might be a good alternative. Anyone see any issues?
Black Baja 12-04-2016 05:37 PM
Used a ton of it. never an issue. Makes life a little easier when you have alignment issues.
thirdchildhood 12-04-2016 07:16 PM
It's all I will use even for very short pieces.
getrdunn 12-04-2016 07:43 PM
I'm glad this was brought up. Currently have no need for it but good to know.
f_inscreenname 12-04-2016 10:39 PM
I use hose with wire for anything over a few inches. Don't want to sag over time. Now for elbows just the plain old rubber ones.
http://i.ebayimg.com/00/s/NDI2WDY0MA..._id=880000500F
splashandburn 12-05-2016 06:57 AM
Thanks for the replies. Wanted to make sure it wasn't going to be an issue before installing.
Wasted Income 12-05-2016 12:13 PM
I've used it in the past as well, with good results.
happy hours 12-05-2016 07:20 PM
I recently used silicone hump connectors and short pieces of straight to tie the downstream elbows to the y pipe. ( thru prop exhaust). Way easier to work with, reduced stresses on y pipe due to movement and the blue makes the boat appear like 5 mph faster. Bought mine on that large Internet auction site that runs a with easy for pennies as compared to local Goodyear rubber and hose store.
splashandburn 12-05-2016 07:36 PM
We're all talking about this stuff right?
http://www.ebay.com/itm/272267420294
happy hours 12-05-2016 09:29 PM
Yup
