-   -   Stem Pocket Lines on 502 MPI Intake (https://www.offshoreonly.com/forums/general-q/343103-stem-pocket-lines-502-mpi-intake.html)
hadleycat 12-13-2016 09:28 AM
Originally Posted by ezstriper (Post 4509001)
believe they are 90lb had a friend that help set the whole EFI deal up got them for this app, only reason did not stay with it was could not stop RFI interence from damn MSD dist or box
Paypal sent, Your Inbox is full ezstriper. Thanks again
buck35 12-13-2016 09:41 AM
Whats the full on retail for a setup like Hadley just bought vs. the one mt showed?
ezstriper 12-14-2016 07:14 AM
From what I have seen/read the front mounted TB intakes are terrible under boost, everything blown to back of intake, bounces around and then is a crapshoot what cylinders get what, seen 40+hp gains on LS stuff, only reason to run that style is if there is not room...my .02
hadleycat 12-17-2016 11:59 AM
Received the intake yesterday. Its a real nice piece. Thanks for the great deal ezstriper
ezstriper 12-19-2016 02:49 PM
sent you PM on injectors
hadleycat 04-05-2017 08:54 PM
Update on this issue. I found that the hydraulic lifter on the tulliped valve was seized. Plunger would not compress at all. Not sure if this was the cause of the tulliped valve as maybe it was not closing fully and transferring heat to the head or if the tulliped valve caused the lifter to seize. Disassembled the lifter and reassembled and it seems to be fine now. Any thoughts?
