Bad set of rings?
Bad set of rings?
So I got out my file fit rings to start fitting and some how both the top and bottom rings have .034 without even touching them to a filer. The bottom ring is even marked with the correct bore (4.530). Anyone ever come across this issue? They are a name brand and came with my pistons. According to their chart I should have around .020.
Are you putting them down in the cylinder bore ? And if so, how far and what kind of tool to square them up in the bore ?
Yes I used a summit ring centering tool to make sure they are square and down in the cylinder. I looked the part number up and they are file fit rings and I got these with the pistons I ordered. Yes rechecked the cylinders too just to make sure I was not losing my mind.
They are getting me a new set.
