disk brake conversion???
I've got one drum thats shot is it worth changing over to disk's while I'm at it????I pull a 31 Sonic about 7500 lbs pluss gear and fuel..looks like you can do it fo around $200 per axel....
Dyno
I switched mine over 2 yrs. ago for 300.00 on 2 axles and have had no trouble.www.kodiaktrailers.com They stop great and you can buy replacement pads at auto zone. |
i basicly just rebuilt my trailer!! from ALL new springs to bearings/races....the calipers are from a 1990 beretta (sp)....took sometime to figure out what the hell they used...$12 per caliper...they car/truck(rotors) they use are FAR cheaper to buy at your local disount auto part store:rolleyes:
Unless your in salt water and need stainless rotors and plated calipers.
I converted mine from single axle drums (for some stupid reason) to single axle discs:( and it didn't stop as good). Last spring I added discs to the other axle...WOW:eek: them suckers DO stop!
I have about 7500lbs behind a Tahoe and it stops like its not there. |
disc brake conversion
Dyno, I just switched my 32' trailer over from surge drum brakes to surge disc with stainless rotors. They came from Northern Tool Co. Approx. $110 each wheel. They come with hubs and bearings, etc. A great kit considering that my bearings needed to be replaced anyway. The only thing you have to do when switching is punch a hole through the diaphram in the rear of the master cylinder(this info is in the kit). I have had no problems with mine since replacing. P.S. Had to add a lockout reverse solenoid at the master cylinder to allow you to back up @ approx $45
I changed to disc 3 yrs ago and have not one problem. With
drum brakes i had to adjust them after every trip and replace them every other yr. |
bit the big question remains ......is it worth it??????I pull my boat about 3-5 times a year, a couple trips up north......about 500 miles round trip..
I think so,I always had trouble with the linings coming of the shoes and a trailer that is pulled alot is as bad as one that sits because the linings will still rust at the rivets and the shoes.Disc are probably 90% decrease in maintaince.Just my .02
rebuild stock brakes every 2 years/used or not!
vs no rebuilds in ? years for disks? It's a no brainer for me, I hate doing brake cylinders and shoes, not to mention the time and bother to do it. Do the discs....you will never regret it and resale will be higher also. |
| All times are GMT -5. The time now is 08:22 AM. |
